Need some OEM part numbers
574-240sx
Car: Nissans, Toyotas, Subaru
I need OEM part numbers for the 97-98 240sx. I need part numbers for both front headlights assy and the complete rear tail light assy.
robbbby
I don't know why i'm coming up with 2 different part numbers for each but this should get you started
LH Rear Lamp Assembly26555-81F25-26555-70F25-
RH Rear Lamp Assembly26550-81F25-26550-70F25-
Lamp Assembly Backup 26540-70F25-26540-81F25-
Lamp Assembly Head RH26010-70F25-26010-70F26- 26010-81F25-
Lamp Assembly Head LH 26060-70F25-26060-70F26-26060-81F25-
I'm guessing the 2&3 different part numbers for the same stuff is for all the countries. Regardless they are all fairly similar.
574-240sx
Thank Robbbby for the info.
