Need some Knock Sensor help
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
Hello- My 94 Q is idling rough and seems to be down on power. The last time it did this I found a bad injector and a marginal injector and replaced both. I checked all 8 injectors tonight and they all read 11.5 to 11.6 ohms which is in factory spec.
My question comes about the Knock Sensors! When tested as per Q45.OrgI get no reading on them at all. A big fat ZERO! I have no Check engine lights.
So my question (After much searching) will bad Knock Sensors always trip the CEL and is a big fat ZERO an actual indication of bad sensors or did I just perform a harness test instead?
As always, thanks for your help
Scott
pdqwrx
Never mind about the KS harness. My meter had almost dead batteries and would read voltage but not ohms. A new battery later I have 565K on one KS and 570K on the other.
I will however take any other suggestions....
I have checked or cleanedThe MAF and HarnessThe InjectorsThe KS
Thanks againScott
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
bad spark plugvacuum leakEGR partially opendirty/sticking AAC
...and a bad injector (clogged, leaky) is still possible even if they ohm good.
daegrigg
Car: 94 Q45, 95 J30T
Check fuel pressure. Should be about 34 psi with regulator vacuum connected and about 45 with it disconnected.
Check fuel pump control module and pump if pressure is not near spec.
Don
