o_alcha3 wrote:I am not a pro but from what i have run into, alot of times when an alternator is shot the battery needs to be replaced b/c of draining. But if not, I would take a volt meter, check the battery, it should be round' 12, then turn the car on. check it again, it should be 14. (Cleaning the battery post and the clamps is always good.) If those check you then check grounds. Make sure all three connections on the alternator are tight and the washers or area's of contact for the metal are not corroded. Then make sure the battery itself is well grounded on the body and motor just incase. If all checks out then I wish you the best of luck. Let us know what the problem is.
Definately do all those things and be sure to test your ground. Try wiggling the mafs around and see if that helps. It really sounds like a mafs problem or ecu to me, but it could just be the battery. Normally after an altenator goes, the battery comes right after since a drain like that is so hard on it. So my guess is ground, ecu, battery, or mafs, and maybe the o2 sensor. So i wish you the best of luck and keep us posted on how the problem goes.
JimmyMethod wrote:Man...they should like, have engine specific forums...Then you could post this in a 'KA' type of forum...and other people could make posts in 'SR' and 'CA' type forums...that would make it flow much better...
Oh wait...
you know, who cares where he posted. this is the 240sx and silvia forum. he has a 240sx and his problem is in his 240sx, so the section listed is appropriate. If your not gonna try to read his post and help him out, just don't say anything. we are here to try and help, not criticize
