OutToWinPAHC wrote:You would need to have the block machined and balanced. Best to do that first to see if you need a thicker head gasket. You need many more little gaskets, new timing set, should do a new oil pump, dial in cams and shim lifter buckets, valve stem seals, guides. Look into new springs, bases, retainers and locks, valve if your doing a good bit of boost, maybe upgraded cams, NEW waterpump, Damper pulley, and then all your turbo stuff.
oh my goodness lol, wel is there any kits that are complete?
also how much extra do you think i will need in parts for this rebuild?
wat i was planning on doing was to rebuild the car so it runs fresh, with new forged internals. And i would keep it N/A for a while. Only mods i would do to it would be exhaust, intake and a nice cam.
Then as time goes on i would purchase a turbo kit, and run low boost, wanting to push like 250 whp
then after that i would get a bigger turbo and aim for 350-400 whp. (maby 450 at the most)
now will some stock parts be able to hold around that? that way i dont have to replace something that will hold up fine
lmk
thaks
(just as an estimate, whats an average cost of labor to do a rebuild?)
also i found this one:
http://www.amsperformance.com/cart/AMS- ... d-Kit.html
will this be complete? or is there anything else i need?
