Now does this mean that the ABS system in the S13 is only a 2 channel front brake ABS system, and it doesn't work on all 4 wheels?
Because I really like ABS, and before anything becomes crazy, There is NO one in the world that can modulate brakes as well as a 4-channel ABS system no one, unless if you got 4 brake pedals one for each tire, and 4 extra legs/feet for it
Because it sounds really stupid when you lock up the rear tires, but you don't lock up the front :/
If anyone was wondering, I was looking at a 12.2" slotted vented rotor with 4 pot clalipers for the front, and 11" blank vented rotor with 2 pot calipers in the rear, with brakes like these and some hard braking I could see tires locking up, and there is a nice flat spot in your tires.
So who has knowledge on how effective it is? This seriously could be a deciding factor on if I get this car or not
