need some info on BOV and turbo
DBo
Car: 1993 240sx Sr20det
im want to boost between 15-18 psi. i have supportin mods of it and im also about to get a tune. my questions are what good bov should i run and should i run it vented or recirculated. also i have a t28 from an s14 sr wat would 15-18 be safe on that turbo or would i be pushin it?
turbo and bov i currently have is a s14 t28 and a Top speed Bov.
i eventually want to upgrade turbo to a gt2871r with a .64 a/r
240_SeX
Car: 1992 240SX SE
You really should search...
on a MAF system its always best to recirculate the BOV.
15-18 should be ok, 18 is about the edge of the efficency range.
Not too much exp with the top speed stuff but it should be fine.
DBo
i have searched . i just want to get other peoples opinions and info about products they are using
hpballer76
Car: 97 s10 slammed dd.. 89 hatch s14 sr project...
i would also like to know what you can run the s14 t28 at with a good tune
240_SeX
Car: 1992 240SX SE
Again, 18 psi is about the edge of the T28's efficency range...
