Syntax360 »
https://forums.nicoclub.com/syntax360-u3690.html
Mon Feb 16, 2004 5:31 pm
Your biggest hurdle is going to be getting the motor in there, but if you have the fabrication skills, great! I've seen the VG30E in there, but never an ET - might have to chop the firewall a hair?Anyway, I think the standalone is overkill. You can probably hit those hp goals with fuel pump, adjustable fpr, and maybe supplementary injectors (like the SDS EIC).You might consider using a VG30E motor and converting it to turbo, leaving you with 9:1 compression - this will limit the amount of boost you can run (unless you DO go standalone + injectors), but you will be able to hit your #s easier. In other words, you can probably easly reach you goal, but you might put a ceiling on it.It's going to be easier to achieve your #s w/ a T3/T4 hybrid - most people opt for the T3/T04E 60 trim i think - check out Z31 for more info.It's doable, but most VG folks steer clear of this forum - Z31.com is going to be your most powerful resource regarding the motor, and probably the 240SX technical/general for getting the actual motor into the car.Good luck!
