rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Sat Mar 15, 2008 5:56 am
OK, if you are doing cams, remember, you have to match your valve train with your cams, i.e. if you are going with crower stage 2 cams, then crower titanium springs & retainers, and stainless valves are required. Also required is a clean up on the heads (anytime you take them apart you have to clean them up). And don't forget to get NEW* head gaskets. Cometic makes about the best ones around, search the internet for the best deal on those. Also since you have the Kinetix plenum you cannot use a spacer, there fore i see your interest in the manifold. Unfortunately i have not dealt with that, but have only heard positive things about it. The only thing is, i am not sure on if you need bigger injectors for stage 2 cams or not, trying to get that answer my self. I want to build my heads all Brian Crower, and i am already looking at $2000 in parts + gaskets, that doesn't include if i end up needing injectors. If your looking for cheap, go with the manifold, if you want to spend a little jack, heads & manifold. I plan to buy the Kinetix SSV manifold eventually, so i am not gonna buy the MREV my self. Let me know w/e you do & how it works for you.
Me= Kinetix V+ plenum Injen CAI Helux throttle body spacer Invidia N1 cat back
