TunerTrifecta »
https://forums.nicoclub.com/tunertrifecta-u81482.html
Wed Dec 12, 2007 5:20 pm
From experience, usually the door inserts are "welded" in with plastic welds. It looks like a big melted chunk of plastic that's been flattened out. The easiest way to remove them is with a dremel, the "correct" way to do it is to melt them, then when you put the door panel back on, re-"weld" them.
I've recovered my entire interior from the inserts up in gray vinyl and red suede, and I can tell you it's no easy task! Feel lucky you were able to purchase pre-done panels. How much did you pay, if you don't mind me asking?
