miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Thu Aug 16, 2012 10:42 pm
No harness or caps
What do you mean by series? Link me to one, then the other.
The normal Hi/Low, which will be cheaper, is lets say you go with 6000k as your temp, your lo-beams are 6000k hids, the hi beams will just be normal halogens.
Bi-xenon - Again lets say 6000k, your lows will be 6000k, as well as the hi-beam.
In my case, i ordered replacement bulbs off ebay for $12.50, very reputable seller, and you cant go wrong for 12 bucks, but they actually dont have any "hi-beams" built in, meaning that i dont have highbeams. I dont care as i never use highbeams, and in order for the foglights to stay on with the highbeams, you have to eff around with the light stalk by the steering column, and i dont feel like going through the trouble,
the fog-light drl mod i did is fine for me, basically allows me
Fogs on by themselfs
Fogs with parking lights ( if thats what they are called )
Fogs with headlights like normal
But no fogs with highbeams ( this is factory anyways )
Just depends on the car, here you have to mess with the stalk and some extra wiring, in my audi for example, it was just modifying a relay, and i have the ability of
Fogs standalone
Fogs+Headlights
Fogs+headlights+highbeams ( the housings are different then r50's obviously, seperate highbeam bulb, and projector low-beam )
Fogs+parking lights
But yeah, felt like i would explain that last bit so you understood the in's and outs.
