Chaotic_Warlord »
https://forums.nicoclub.com/chaotic-warlord-u26051.html
Sun Mar 13, 2005 8:51 am
I have a 95 S14 with super high mileage and I know it has some problems because of that but I'm poor and can't swap in a newer lower mileage KA to build on. Here's my problem, I have a leaking valve cover gasket that I plan to replace hopefully this week when it supposed to warm up a little. I don't know if I'm leaking anywhere else yet, haven't had the chance to get a really close look at the rest of the engine block, it's been too cold to take it to the car wash and hose down the block with degreaser and clean it yet. Here's my problem, I've noticed that under hard acceleration from a standing start, I get good acceleration and all which is good (I don't do this very often). Afterwards, for the first couple of seconds when I press the gas theres a couple big plumes of smoke. It's white, not black if that makes any sense to you guys. Would this smoke problem go away after I replace the valve cover gasket, or is there a more serious problem that I need to be alerted to. The rest of the time it doesnt smoke at all, not even when on the highway or any other time, only for the first couple of seconds after I shirp the tires a little from a standing stop (ie red lights and stop signs). Any help you guys could give me would be great, please don't just say swap your engine or rebuild your block, I'm poor and can't do that just yet, I can only do minor repair jobs. I should also mention, I do have a tiny coolant leak behind the radiator (possible lower hose leak). Thats all the info I have right now.
