Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Mon Dec 21, 2009 6:02 am
Could be one of the many hoses under the plenum, turbo coolant lines/hoses, or maybe even heater core hoses.
If you are in the mood some day to pull the plenum, it's a great time to do the bypass as well as replace the heater core hoses. It eliminates all those problematic hoses that will one day go, usually one at a time, and leave you stranded.
Best way is to find the current leak is pressurize the coolant system and have the car raised so you can look where it's coming from, from all angles.
