Need some help with things for swap
S13-Chuki
Alright first off i searched so dont tell me to search.im buying a sr20det with the following
S13 SR20det, Cometic Head Gasket, ARP StudsGreddy Style Intake, Polished, Needs Small Piece WeldedTop Mount Fuel RailLightweight Aluminum Pulleys
Top Mount Turbo Kit w/ Turbonetics T3/T4 Turbo & Evolution WastegateLog Style Manifold, Downpipe, Wastegate Dumptube
5 Speed TransmissionStarterFlywheelNew 6-puck Clutch, Off-Brand
Wire Harness, taken out of swappd car, needs some minor repairAlternatorPower Steering PumpZ32 MAF
all im wondering is what else i need for this swap.
S13-Chuki
Alright this is what i got on the list sr20 rad,e fan,motor mounts.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
FMIC?
S13-Chuki
ow ya i forgot that thanks,anything else?
240_SeX
Car: 1992 240SX SE
ECU?BOV Intercooler piping, couplers, clampsRadiator HosesHeater HosesSome type of tunning
S13-Chuki
how much do you thing the tuning would run me?
240_SeX
Car: 1992 240SX SE
Depends on what you get...
alex87
Car: 92 240sx red top
you also need a bigger fuel pump and hopefully you have the stock ka wiring harness cause you need a few plugs from it cause the pinouts on a few of the sr harness don't match the chassis. There are threads for the wiring which is actually pretty easy. You also need to redirect the heater hoses which is harder when the engine is fully in. That engine sounds sweet though. Also when you set the engine in the aiv piping is going to rest on your steering column you need to cpmpletely remove that system.
