need some help with noise in my ka24e
kickadog55
Car: 1990 240sx hatch
so i recently put a diff engine in my car cause mine jumped time.
when i got it started it was making a loud ticking noise.
i switched out the spark plugs and wires and it helped with alot of the noise and it runs alot smoother idles at about 800.
so i decided it must be the timing chain so i installed a brand new timing chain guides and tensioner. even though the old ones were not bad at all.
but the noise will not stop i hve fixed all exhaust leaks replaces the lifters with ones i know work good.
when you rev it it ticks lil louder and faster when you drive it sounds a little like a diesal and ticks t idle.
anyone have n idea?
Steve Lloyd
really sounds like your chain is bad. If it's stretched to much, the tensioner and guides won't do anything. There is a way to measure the slop in the chain, but I'm not familiar with the procedure. Your best bet is to replace the chain before it wears through your front timing cover.
kickadog55
sorry i wasnt specific its a brand new chain aswell i baught the timing kit and installed it all guides, tensioner, chain, and sprockets. the chain is nice and tight
SirSilvia
Car: Sold both my babies
do you still have the EGR in it?mine clicked alll the effin time. I thought it was a valve clicking.
kickadog55
ya still has the egr ill swap it out with an xtra one i have but it def sounds like its come from under the valve cover somewere
