mzeo »
https://forums.nicoclub.com/mzeo-u18571.html
Wed Feb 04, 2009 4:15 pm
There are a few things you can check to fix that.
1. Double check the +/- on the subs are going to the +/- on the amp. So it's not + to -2. Make sure channels 1/2 & 3/4 are both set to low pass on the amp's crossover, and that the gain is set to the same level.3. If there is no switch for it on the amp, you might have to split the RCA signal so that it's going to both input channels.
Most likely #3 was the cause of the quietness. That being the case, the quiet sub wasn't getting any input. 2 Y adapters will fix that though.
edit: The MODE switch on your amp set to 2 should do the trick without an adapter.
Modified by mzeo at 9:29 PM 2/4/2009
