slickster1013 »
https://forums.nicoclub.com/slickster1013-u31831.html
Wed May 16, 2007 8:21 am
Ok well i've recently started on rebuilding my motor for when i turbo it. ( stil need help on deciding what turbo kit to go with btw) Anyway, so far i've got CP Pistons, Sportsman rods, 264 cams, stage 4 clutch, fidanza lightweight flywheel, lightweight underdrive crank pulley, fel- pro gaskets, calico coated bearings, and i've got it all put back together. I got my block bored and honed and got it shaved a little, so my compression will be about the same as stock, possibly a little higher, but not much. Oh yeah and i got all my stuff balanced too. But as i was saying, i got it all put back together and stuff,besides my head. So i was wondering if you guys think i should do some head work? Like bigger valves and stronger springs...maybe a 3 angle valve job? And another big thing i've been wondering about is an aftermarket Intake manifold? I've seen them before, but can't remember where....so if you guys know where i could purchase one let me know. AND ANY OTHER OPINIONS OR IDEAS WOULD BE APPRECIATED!!!! Thanks guys
