XenonSE-R wrote:In the case of the 370Z, a muffler delete without a tune will cause the car to run rich (more fuel than air in the air/fuel mixture), which leads to a decrease in fuel economy among other potential issues.
I don't know if this will happen on a 2.5 Altima, but it is a real possibility. I know in the case of older 2.5s with the precat (Sentra SE-R Spec V, 2002-06 Altimas), running rich increases the possibility of precat deterioration (especially if you run cheap gas - many people do, whether intentionally or unintentionally). While Nissan has worked out the kinks in that system for 07-up 2.5s, you could potentially open up that bag of worms again. Just to put it in perspective, Nissan replaced many engines due to this issue, and likely will try not to help you if they find you've modified your setup.
This may seem extreme, but it is true. You're likely a long way from this happening (and it may not ever happen) but the gamble is up to you. I have two suggestions for you:
1) put the muffler back on
2) buy a full exhaust and do it right.
In the case of running straight pipes, the ECU is calibrated to manage the engine for the length of piping the car came with from the factory (backpressure is namely the affected attribute), and that basically means that in Aphu's case, he is running the same length of piping with less resistance, which to an ECU translates better than less piping coupled with less resistance (even less backpressure, which can also translate to a loss of low end power, which you do not want in most cases, especially in the case of a 2.5).
Just my .02. Sorry for the info overload.
Hmm, very interesting, thank you. Well I definitely don't want to leave it as it currently is (just without a muffler on) I am just trying to figure out the most cost effective way to do a good setup that looks, sounds and performs good. Didn't really want to pay $700+ for a cat-back setup so I was thinking about just doing the axle-back for now, but name brands even on that is still $400-500+ (Stillen, borla, Magnaflow, etc.). I did find the Tsudo axle-back one for under $200 shipped, however, it looks like it has the longer piping which is made for the 3.5 model so I assume I would need to do some modification to my stock exhaust in order to fit it. Plus the seller hasn't responded at all to any of my questions regarding it so that doesnt make me want to buy it. I guess best bet is to put exhaust fully back to stock and visit a local muffler shop then. Thanks all for the input. One other thing though, I am planning on doing the Stillen header soon, any idea how that will affect the sound of the exhaust (louder, deeper, rasp, etc.)? I am wondering maybe if I should just do that first and hear how that sounds on stock exhaust setup before I go getting custom stuff done... I haven't been able to find anything on people that have the 2.5 and just done header and intake and left the stock exhaust alone.
