Need Some Help With My 1993 Q45
CroQ45
Car: 1993 Q45
Hi I have some problems with my Q! Please Someone HELP Me!!!!
I just installed 8 Injectors, I did the Plenum Work Myself!After The New Injectors were in And Plenum Back W/ All Hoses Connected!I started Her Up. Now For The Problems!
1) She Idles at 1500 RPMs2) White To Light Blue Smoke Coming From Tail Pipe.3) Took Her For A Quick Ride, Seems Like Power Loss.4) A Whining Noise Coming From Engine Or Maybe Under Car.
NOW WHAT I DID!
1) Cleaned IAC Valve2) Cleaned EGR Valve3) Cleaned Plenum And Egr Tunnel4) New Battery5) New Spark Plugs6) New ShotGun ( If All Fails) ( The Car Not Me)7) Checked Injector Leaks ( Top Of Engine)8) Painted Plenum red.9) All Injectors Ohmed Good!10) All New Injector Rings.
BEFORE THE PLENUM JOB!1) She ran bad I Knew Her Injectors needed to be replaced!2) She Did NOT Smoke At ALL! (Drove Her A while)
She Sat For 3 Months In My Driveway!
NOW She Smokes from Tail Pipe And Idles High, Plus Loss Off power!
PLEASE SOMEONE HELP ME!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Nice looking! Did you adjust the IAC valve. If you did, time to check for a vacuum hose leak.
Hopefully you did not remove slack from the throttle cables.
CroQ45
Car: 1993 Q45
Yea I did adjust the IAC valve, But Whats Up With The smoke?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I would suspect a bunged O ring on an injector.
When was the valve cover job done?
CroQ45
Car: 1993 Q45
The valve cover job was done 3 months ago!I forgot to add that!
CroQ45
Car: 1993 Q45
If it is a bunged O ring, How can i tell?How can i find out witch one?
Q45tech
Use a Consult to adjust IAC and read the IAC solenoid duty cycle.
Are you sure it has been turned in fully then out 2.5 turns?
CroQ45
Car: 1993 Q45
I dont understand what could of changed, Before the plenum job she idled somewhat ok.. And no smoke from tail pipe, Now after the job all this???
