need some help with install of tomei 70mm TB
drifter_x
Car: 89 s13 with blacktop and alot of mods, 90 rx7 lsx swap, 88 rx7 5.3 swap, 95 G20 mostly stock swap to all G20t with 5sp, 88 starion, 87 starion, 95 240sx base with jdm kouki front
i have s13 blacktop with gt2871(and supporting mods) built head and so on... i have tomei 70mm tb on greddy intake throttle cable is to short that easy just get a longer one, and what tps to use i have tried a few from other sr20de and sr20det dont fit it.
drifter_x
is anyone using tomei tb with greddy intake?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
The whole cable is short? Do you have a DOHC cable? You could cut the sheathing if it is not sticking out enough.
drifter_x
the throttle cable isnt a problem just use a longer on i have a g20 cable its plenty long i can hide most of it. The tps is what i can get i have tried three different nissan tps with no luck
drifter_x
think i have found what i need a n15 tps
