need some help with injector latency ca18de+t 750cc nistune (engine wont start)
xsrpm.com.au
Car: nissan silvia
Hey every one I’m having a bit of trouble with Nistune ok so i have a q45 afm & 750cc injectors i installed the injectors and afm, has been wired in so I don’t want to go back to the old afm cbf or the old injectors apon removing the old injectors they were looking worse 4 wear and plastic was breaking off the injectors any way I have spark I set the injectors up through Nistune 1st it won’t start I was going to change the afm as well but don’t know the Q45 max hp to do the calculation within Nistune I will up load the .bin file it that helps.
P.S.im using a ca18det engine loom and ecubut a na coil pack loom but that shouldn’t seem to matter as i have sparkRegards Davidhttp://www.xsrpm.com.au/nistun...c.bin
Modified by xsrpm.com.au at 11:05 AM 9/6/2009
