98KA24DET wrote:So that 12:1 is 12lbs of fuel pressure for every 1 lb of air.. right..??So if you say 14.7:1 is stoiciometric, then why does everyone say that 14:1 is WAY TOO rich..??Another, do you know how much pressure the stock ka pump can push..??
No...erase your mind completely of the 12 pounds of fuel pressure per pound of boost. Just let go of it. Think of it on an atomic level. To get a perfect burn where there is no left over fuel or oxygen atoms/molecules, you need 14.7 atoms/molecules of air for every atom/molecule of fuel. This may be different with fuels other than gasoline. The mixture has nothing to do with boost. A normally aspirated car still has an air/fuel ratio.
Now there may be some confusion since FMU ratios can look like A/F ratios. They can have an impact on the A/F ratio, but the FMU ratio has nothing to do with the A/F ratio itself.
