Sentientbydesign wrote:Call up the insurance. You did what you needed to avoid the accident. They need to fix you up. The alternative is that they paid for you hitting the person in front of you...You weren't getting R**D H**D were you?
If he has collision coverage, they'll pay for the repairs less the dedcutible regardless of fault. BUT...generally speaking, if someone hits a fixed object without contact from another vehicle, they will usually be found at fault. The only 2 circumstances I've seen where this wasn't the case was in avoidance of a head-on collision at 60 mph (presumably both cars going at least 60) and in a case where a child ran out into the road. Both cases involve a very large likelihood of severe injury or death. Someone coming into your lane going in the same direction typically doesn't apply.
Just so you understand the theory behind this, when a person avoids an accident, they are still required to maintain control of the vehicle. Swerving and hitting a fixed object technically means the driver swerved too much. Had an impact with the other car occurred regardless of if the driver hit the fixed object first or not, it would be clear that the cause would be the other driver. It is a judgement call, but typically it goes against the driver hitting the fixed object if there is no physical contact with another vehicle. This is under the assumption we are talking about a lane change type of situation. If its to avoid rear ending the car ahead, your at fault either way.
Sentientbydesign wrote:Telco,
I agree that the Infiniti Techs "should" know more than an independent shop, but this, unfortunately, is not always the case.
I would take the car to the dealership for the frame portion and take it outside for any body repairs. Dealership recommended bodyshops sit very low on my list.
Few Infiniti Techs will have any real knowledge about performing body work. Frame, body and paint repairs tend to be a blend of technical and artistic abilities. And further, require a very different set of skills to perform. There is some overlap, of course, but I would prefer to find a good body shop rather than an Infiniti technician to do my body work (other than bolt-ons). Frankly, few dealerships have body shops on sight and even when they do, they likely just occupy the same space (perhaps under ownership of the dealer). Every body shop I've worked with located within a dealership will take almost any make and model to repair as the repair methods are fairly universal. In fact many direct repair facilities for insurance companies are dealer body shops.
A last point to think about is that many dealers don't have body shops on site. Which means they don't have access to a frame alignment machine. They would have to outsource checking it and having it repaired if necessary.
It is a bit of a toss up in this particular case though as it seems the damage appears to be mostly related to the suspension.
Also, did anyone else notice that the shock looks like it is bent. Maybe the camera lens is causing a bit of a fisheye effect, but I'd make sure that is straight as the part that looks bent looks to be right about where that sway bar might hit it. And its pretty obvious the sway bar deflected quite a bit.
