Hello, I have been lurking NICOclub for a while now - usually whenever I google a problem I'm having on my Z32, NICO has what I need.
I need some help:
Started a few weeks ago:
When starting my '96 300zx NA M/T in the morning, it would start - rev to about 1,200 RPM, stay there for about ten seconds, then drop to 800.
After about 10 seconds idling at 800, it would drop to 500, bounce from 500-600 for a few seconds, then rise back up to 800. It then drops back to 500, repeating the process.
It did the same when it was warm as well. Once driving - there is no hesitation. Only when idling is there problems.
The Check Engine Light was on, so I ran it for codes, and got:
P0605
P0325
I cleared the codes.
After a bunch of searching - I came back with a list of things to do:
Check MAF, check harness connectors for green corrosion, check TPS, check IACV, adjust idle, change sparkplugs..
I changed sparkplugs from the Iridium plugs that the previous owner had, to NGK PFR6B11's.
Cleaned MAF sensor with MAF Sensor cleaner.
Checked TPS, CAS, PTU, Coolant/Water connectors for corrosion. (only checked, they looked alright so I didnt do any cleaning)
Cleaned Throttle Bodies
Put some injector cleaner in
Vacuumed the Stillen intake filter
Adjusted IACV, and half-*** cleaned it
No luck.
Currently:
No Check Engine Light popped back up.
When starting it, it does the same - rev to 1,200RPM for 10 seconds, drops to 750/800 - then within 5 seconds, drops to 500 and then back up to 800
But, something different started:
In first gear, it would buck right after I took off. I put it into neutral, coasted for a few seconds, then put it back into first - no more bucking.
I thought I noticed that my 2nd gear was being 'dragged out' - WOT, the revs accelerate, just slower than usual (hesitating?). Then, after getting onto the freeway, and getting up to speed (70mph), I put it into 5th WOT. My RPMs start to drop, as well as my speed. What?!
WOT in 5th @ 70MPH, I lose speed. Downshift to 4th gear:
WOT in 4th @ 60MPH, I'm not losing speed, but I'm not accelerating either. Downshift to 3rd gear:
WOT in 3rd @ 45 -50MPH, it finally kicks in, and I have my power back. I upshift to 4th, and get back up to speed at 70MPH. Upshifting to 5th = lose RPMs again. 4th gear = stay at current speed at WOT.
Dropped the Z off to a Toyota mechanic I know who scanned the Z for codes:
P0605 is back.
And the mechanic was confused why Fuel System 1/2 went from Open Loop-Fault to Closed Loop.
Also, why the Air Flow Rate from MAF Sensor was only 5.07 g/s at 2,350 RPM --- 2.71 g/s at 637 RPM
(see pic)
http://i.imgur.com/t53Z7nb.jpg
Other things maybe worth mentioning:
My radiator fan is ALWAYS on. Even when the ignition is at ON, but not started - its on. When I start the car, it stays on. Its always been like this?
5th gear grinds if I shift from 4th without letting it coast in neutral for a few seconds.
My car gurgles when letting off gas at high RPM
I will try to get a video posted of a cold start, warm start, and driving as soon as possible.
Any help is appreciated on what I could check next, suggestions, etc.
300zx-idle-problems-t340045.html
Has pretty identical issues as me, besides hes TT and A/T
Theres a post there that suggests that the Knocksensor might be the culprit. I did get a Knocksensor code a while back, but its never popped back up. What do you experts think about that?
