PapaSmurf2k3 wrote:You can put it off if you want to.
My BMW has had the variable timing on the exhaust side broken since I've owned it. Supposedly I'm loosing some low end torque, but I don't notice it at all. Mine is caused by the solenoid that controls the actual cam positioning, not the sensor. So I don't get any fault codes. The fix for me is quite in depth, not just a sensor replacement, so it's staying broke.
If it runs and drives fine, it shouldn't have any detrimental side effects on the motor itself. Like James said, maybe a tad worse in the mileage department and some loss of low end power.
