No SES light, either? Verify the oil pressure light illuminates when you turn the ignition to "ON" with the parking brake set.
If you plan on taking a look at the power valve screws, make sure you get the first three gaskets listed in that thread:
16175-4w000 (throttle body)
14033-4w000 (right side, between upper and lower intake plenum also called 14010A*)
14033-4w010 (left side, between upper and lower intake plenum also called 14010AA*)
I went without the last gasket since I don't plan on removing the lower intake manifold collector. Just be careful to not drop a screw down one of the valves (though I've read that the valves have a fair amount of resistance so they shouldn't move without some force applied; can't verify yet as I haven't done this job yet). I suggest using some red (permanent, high-temp) threadlocker as there's no reason for the screws to ever come out again for maintenance.
At 100k mileage, swap out your spark plugs while you're this far down. The change interval is 105k. That is, unless you see one or more screws missing - in that case you need to decide what to do about it, as you may have engine damage.
