There are a few, they connect to the valve covers which are semi-hidden by the intake plenum. I would also make sure your throttle cable isn't binding, and perhaps try to throw some lube down it. There are kits you can buy to force spray lube into throttle cables.
If it were me, I would remove the throttle cable and check if the butterflies return to their closed position ok. Then you know its the throttle cable sticking, if not you know it is a problem with the throttle bodies.
That is a picture of the pvc valves I am referring too.
Also I would clean the throttle bodies with a toothbrush and throttle body cleaner spray!
