need some help
streetbikestunta420
Car: nissan 240sx/red top sr20det
ok so a couple days ago i hit the bottom of my s13 real bad and now it leaks oil BUT only while it is running, when ithe engine is off no oil leak.so i went under and turned the car on but found no damage and its leaking from what seems to be the upper oil pan i guess because the bottom part (black stock sr pan) dosent look like its leaking it looks to be right above it but i cant see it with my eyes (no space)what could be the possiblilities? i though it was maby the turbo line but i checked and its not.please help
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Maybe the oil pan gasket got torn?
Modified by positron_ at 6:25 PM 12/24/2008
streetbikestunta420
come on any help?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Without looking at it, it's hard to tell. If you bottomed out really hard, and it only leakes while running, you may have cracked or broken the upper oil pan.
streetbikestunta420
boro drift wrote:Without looking at it, it's hard to tell. If you bottomed out really hard, and it only leakes while running, you may have cracked or broken the upper oil pan.
yea thats what i think it is too, but as soon as it stops raining ill confirm... if it is can i tear one out of a KA? or do i need a sr one?
