Hijacker wrote:I vote for the cosworth. I love mine!
I would say go with the 1.5mm. Slightly over 9 is a good CR to have IMO.
Your combined metal removed is pretty significant IMO. It equals a hair over 1mm
Yeah, I know there's a good amount of material removed, but that's ok with me as I was looking for a higher comp engine anyway... I read the article on the Cosworth headgasket, it was great and probably one of the main reasons I considered it. I ended up getting the 1.5mm, I figure I can still make solid numbers, have clearance between valves and pistons, even though they have reliefs and have faster spool on most turbo's than anyone using stock comp would. I just need to order a few more things and the motor will be done, then it's injectors turbo and a tune... I'm hoping for close to if not 400rwhp...
Thanks again Hijacker for your input...
