Mistaken »
https://forums.nicoclub.com/mistaken-u52335.html
Mon Sep 17, 2007 5:39 am
Alright so i just finished up my new setup. Cometic headgasket, arp headstuds, brian crower 264 duration cams, brian crower springs/retainers, fmic, t3/t04E 60 trim top mount setup, nismo 740cc injectors, enthalpy tune. My problem is on first start up over laborday weekend the intake cam gear some how came off the pin, so the cam stopped turning. Everything was installed correctly and torqued to the correct specs, i even have pictures showing that everything was lined up and correctly installed before the valve cover went on. Anyone have any idea of how it could have came off the pin even when torqued down?
Also im pretty shure i bent the valves on cylinder 1 and 4 since it wasnt turning and we cranked it for a while before we realised it. Just would like someone to let me know if there is anything else i should expect to be damaged when i pull the head off in a week or two.
Also it broke one of the little rocker arm guides that sit on top of the valve keepers, any idea of where i can get replacements?
