m'ssil80 »
https://forums.nicoclub.com/m-ssil80-u75504.html
Mon Sep 10, 2007 2:38 pm
i was on the highway and got off and i stopped at a light and the car would go very, very slow, the rpm's went up slowly. when i give it gas the car just didnt want to go, it wasnt the clutch because i know if a clutch is slipping, and i did get the master cylinder checked and flushed and everything and they told me it was perfect. so i drove it home even though it had no power, i was too far away to just leave it or pull over. eventually i got home and checked everything and everything seemed normal, well an hour later i tried to start the car and it wouldnt start, just a clicking noise and the fuel pump did come on. well after about 20 tries to start it, it finally started and i decided to take it for a spin, and it ran fine, i had no problems, i didnt understand what happened. and also today it acted funny, i got home from work parked it and put it in neutral and the rpms went up and down, up and down, and it felt like the timing is off or it is misfiring, i dont know if that has anything to do with what happened before. its done it once before i parked it and it started to do the same thing and when i shut it off and leave it alone for a couple hours and turn it on later it runs fine and doesnt do it anymore, any ideas?.....thanks
