S14tat »
https://forums.nicoclub.com/s14tat-u875.html
Thu Aug 25, 2005 7:31 pm
why don't you just go to the low throttle setting and add fuel to the 1000-1500 rpm area? when a car would have a very lean afr, the afr would bounce around and have flucturating vac at idle.
every car has a different dec air settings. but generally the first number would be the throttle position used to get ne2's rpm.
ne1 would be the air flow percentage at that rpm. and ne2 would be the air flow percentage for that given rpm. its best to do it when its cold. when the dec air is screwed up, it wouldn't idle right at all. and it would occassionaly stall. if the settings are done right, it would only idle funny on a cold start up and it would drive fine when it warms up.
