From the FAQ's on
http://www.240sx.org:
Measurement of Compression Pressure
1. Warm up engine.2. Turn ignition switch off.3. Release fuel pressure (See How to Change Fuel Filter)4. Remove all spark plugs.5. Disconnect distributor center cable.6. Attach a compression tester to No. 1 cylinder.7. Depress accelerator pedal fully to keep throttle valve wide open.8. Crank engine and record highest gauge indication.9. Repeat the measurement on each cylinder as shown above.Note: Always use a fully charged battery to obtain specific engine revolution.
Compression Pressure kPa (kg/cm2, psi) / RPMStandard = 1,236 (12.6, 179) / 300Minimum = 1,040 (10.6, 151) / 300Difference limit between cylinders = 98 (1.0, 14) / 300
10. If cylinder compression in one or more cylinders is low, pour a small amount of engine oil into the cylinders through the spark plug hole and re-test compression.
* If adding oil helps compression, piston rings may be worn or damaged. If so, replace piston rings after checking piston.
* If pressure stays low, a valve may be sticking or seating improperly. Inspect and repair valve and valve seat.
* If compression in any two adjacent cylinders is low and if oil does not help compression, there is a leak past the gasket surface. If so, replace cylinder head gasket.
140 psi does seem kinda low
