Need some help regarding gears
4drmadness
Car: 04 g35 infiniti sedan
Hey guys i installed 3.5 gears a couple weeks ago. Im thinking that this was actually a 3.3 because i didnot feel any gains. I want to verify this without taking the pumpkin apart. Does anyone know the best way i could check this? It would be a great help. I want to know ASAP, so i can contact the seller.
Some info:After i installed the gears my rpms are exactly 2875 at 80mph. Im thinking that a 3.3 should get this.
Part numbers arent any help because the numbers on the pumpkin are just the case number.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Your gears are 3.3...thats the ratio and FD for the 5AT. 6MT is like 3100 at 80 mph..3.5 gears.
poms302
when you go from stock 3.34 to a 3.54 it's only about 5% steeper and may be tough to notice. I put the 3.9's(11%steeper) in mine, it was noticeable but not a BIG wow factor. To make you feel better, there is a site that will break down your rpm, you just have to input your trans gearing and FD ratio. I will look for the site!
