need some help please
es sex0727
Car: 1991 piggy???
well it is currently pouring out right now and im pretty sure i have a leak somewhere among my clutch lines. now here is where you guys come in, because i need to know after the hard line that come from the master cylinder what is next? does it go straight from the master cyl to wherever it connects in the end or is there a fitting somewhere that may be leaking or a bendy line that broke or something. btw its on a 1991 hatch. i just need some help because i dont have a garage and i need to get the ball rolling on fixin this hog.
ricebike
2002 Quest
2005 Altima
wonders why no one is replying... maybe it was discussed 1000000x already? :gapteeth:
master cyl -- hard line-- clutch damper-- more hard line-- rubber hose -- slave cylinder
guess you'll have to check those things; i'd start from under the vehicle at the slave cylinder... peel off the dust boot and see if there's fluid leaking from there
others also have deleted the clutch damper as well for easier bleeding and better clutch pedal feel
here's a link to think about doing after you find the failed part that's causing your leak:
http://garage.projectraine.com/content_ ... amper.html
:domo:
