NEED SOME HELP PLEASE
90_240sxx
Car: 1990 240sx
OK so i just finish swapping an s14 sr20 into my s13 and the motor cranks and its got fuel but no spark now before i start cutting tape and start searching through the wiring is there any thing i can test before i do that oh and there is one plug form the s14 wiring that looks like it goes to the fuse box but i don't got the s14 fuse box and it comes form the alt. and the starter wiring i want to know if that could be the problem? cant seem to upload the pics of the plug but will try to upload later Any help will be highly appreciated thanks
90_240sxx
Car: 1990 240sx
ok so i checked my wiring and the plugs from the coils and every thing has 12v but i still don't got spark is it possible that all 4 of my coils are bad ?
sameo2
Car: 93coupe240sxsr
did u check the ignator 90% that will be your problem.
90_240sxx
Car: 1990 240sx
i hear noise from it when i turn the key or plug the c.a.s so im assuming it works also how do you test the c.a.s to see if it works and how do you test the ignator anyways thanks
