boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Wed Jun 04, 2003 6:24 am
If the bores are not damaged, you can get a set of wiseco pistons and have them make them at the stock bore, if some isn't already made. In this case, you would only have to remove the head and the oil pan leaving the block and transmission in the car. Do a light hone to all cylinders clean, clean up the residue from the stones, get the rods re-shotpeened, get some new rods bearings, install the new rings on the new pistons, install the new pistons, install new headgasket and headbolts as well as new water pump and timing belt and you're off to the races again. I don't mean to make it sound easy, but in all honesty your situation is not that bad. You can just turn the boost down to say "10psi" and that should help with the problem you're experiencing.
