Need some help on dropping my car
All things Altima Coupe.
mag23
Need some advice on what you all recommend ro drop my car im keeping my stock wheels and tires all I want is to lower it a bit without it bouncing. I'd like to keep it the way it feels when I drive it now...... if theres such thing
RicerX
Car: '20 Titan Pro4X
Welcome to NICO!
what kind of car do you have?
cheffyw
Car: 2009 3.5 SE Altima Coupe. Satin White.
Welcome.
You have a lot of options but you will never be able to keep ride comfort when you mess with suspension and tires. Seeing as you want a small drop i would just do an eibach pro kit ($150-$200) then you need to pay for an allignment. But like i said earlier you won't maintain the same OEM ride comfort with drop kits.
mag23
I have a 2011 altima coupe
Persian Scarface
Car: 2010 Altima Coupe 2.5 6 speed
Eibachs would be the only way to do. I was in the same position as you since I drive my car a lot. I currently have Eibachs with 18 inch rims and the ride is great. A bit stiffer than stock but still very comfortable. Not to mention the improved handling as well
KazmoKhan
Car: 2009 Nissan Altima coupe
I would recommend D2 racing coilovers. Just put them in my Altima coupe and can only slightly tell any difference in ride comfort.
turbocoupe
Car: 2009 Altima Coupe 2.5 S
I have the Eibach Pro-Kit, and I am very pleased with it. The ride is firm, but it is not harsh. I drive about 350 miles a week to and from work and I have had no problem. I was concerned that the springs would be stiff and jarring. I found the ride is, firm, but smooth. The handling is much improved. The Eibach springs are probably the best mod I have done to my car.
DAAN.
Where can I buy the Eibach kit for the 3.5 SE ?
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
Flyers28
Car: 2008 Altima Coupe 2.5 S
gonna be going with eibachs as well. Planning on doing new wheels and rims but my budget only allows 1 thing at a time so doing springs first. Curious if all those that did springs kept stock shocks/struts. For those that have stock what kind of miles do you have on new springs with original shocks/struts. My car has 75k miles, bought it at 63k, and have no idea if the shocks/struts are original and still in good condition. would it be recommended to replace the shocks/struts along with the new springs? I put a lot of miles on my car a week so it sees its share of bumps quite often.
