I am researching doing a SR20 family engine swap into this;
This is my 1967 Triumph TR4a and it just ate it's under 100 mile professionally rebuilt engine and I am more than slightly fed up with it. It is going to run me around $4,000 to get it rebuilt and I am thinking that for not wildly different money I could install a SR20-family engine and have a better, more modern, better support engine attached to a proper 5 speed that would be both more powerful and lighter. As you can tell from the picture she is a driver, and my intention is to use her for long distance touring events in/around SoCal. (Side note - this is an original paint SoCal car that sat unloved in Seal Beach for 22 years before I pulled it out of a garage and got it running. I've had a number of these and was banking (no pun intended) on have a British engine specialist rebuilding the engine result in the car being good for 75,000+ miles but no luck).
If I may I have several questions I would like to get your coaching on;
1) Is there a specific SR20 series engine that I should focus on for a normal aspirated engine for a good street car, even a mild tune should give me a 25-40% bump in power?
2) I am decent with a MIG, so am not that worried about fit and clearance issues, but will need some help on wiring. I was hoping to get the engine and transmission fitted and then bring it to a specialist in SoCal, Orange County ideally for the wiring help. Is there a shop that someone could recommend that would be able to help me?
3) What 5 speed transmission would you recommend as a bolt on - I should be OK on clearance.
4) Sourcing the engine - any tips or recommendations? I am aware of Soshin USA and JDM West Coast, but I am sure there are others to consider but as a newbie I am not plugged in on where to look?
Thank you again for the coaching!
