Need some help new Infiniti owner
Jondabomb
Car: 1995 infinity j30
Hello all, i just got a hand me down 95 Infiniti and just fix the power steering by finding how to here. It's in good shape but the only thing wrong is that i cant start anything unless i turn on the engine and hit the gas a lil. Just want to listen to my radio without the engine being on. I just got a new batt and check the fuses. Can someone help me out, i search for this topic but didn't see any thing.
Thanks
gotspeed
Car: 96 nissan pathfinder 97 infiniti J30
are you saying that u cant listen to your radio unless the engine is runing? Is your check engine light on?
NismoChi
Car: 94 J30
Do you have a aftermarket headunit?
gr8scott72
Car: 1994 Infiniti J30t
NismoChi wrote:Do you have a aftermarket headunit?
Can you roll down the windows with the key on but without the engine running?
Jondabomb
I cant do anything without the engine being on. And if the engine is on i need to hit the gas a lil to make things work like windows, radio, sunroof, lights.And no the engine light dont go on.
Modified by Jondabomb at 11:27 AM 8/15/2007
gr8scott72
Jondabomb wrote:I cant do anything without the engine being on. And if the engine is on i need to hit the gas a lil to make things work like windows, radio, sunroof, lights.And no the engine light dont go on.
Sounds like an ignition swith problem? Do any of the lights come on on the dash when you turn the key on but not crank the car?
Jondabomb
Nope nothing does
gr8scott72
gr8scott72 wrote:Sounds like an ignition swith problem
Jondabomb
Ok ima check that out thanks alot for the help.
