need some help motor wont start
kickadog55
Car: 1990 240sx hatch
just to start from the begining i was one my way back from kennewick a few months back. my car started ticking loudly overheating and shut down towed it home found out it jumped time.
i baught a donor motor for some things took the old motor out replaces the timing gear replaced the intake manifold and the distributor housing.
now it wont start still so i did a compression test results: 1-90 2-90 3-60 4-90
anyone have any ideas what it could be? also its a SOHC
mychalous
Car: '96 240SX "Silvi"
compression in cylinder 3 is waaaaay too low, find out where it's leaking from and get it fixed. check the valves and your piston rings and try again
smbonn2005
Car: 1991 Nissan 240SX SE
Also check your head gasket as it may be cracked at that cylinder
Modified by smbonn2005 at 7:14 PM 11/4/2008
