Post by oneruffryder42 » https://forums.nicoclub.com/oneruffryder42-u27153.html Sun Jan 29, 2006 9:55 pm
Post by c-rad » https://forums.nicoclub.com/c-rad-u19918.html Mon Jan 30, 2006 4:40 am
If you spun a bearing, you need to make sure you didn't overheat the main cap(s). If you did, you will need a new block altogether because that one is trashed.oneruffryder42 wrote:well i spun a bearing and i want to know what u guys think i should do? my friends gave me these ideas, 1) get the longblock and we will swap it out and built the other block. prob with that is where am i gunna find a good block. 2) go get the motor rebuilt oem style. with just a head gas, and head studs. what should i do i got the money to them. thanks for the help.o and just for kicks my friend wanted me 2 boost 20 psi befor we do the longblock swap if thats what im gunna do. help
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
