white90esex wrote:how can no one seem to know what these wires are?
Plug one I think will go to the starter. I can't tell the length from the pic.Plug seven is for the starting circuit. It will connect to the top connector by the fuse box.The first eyelet is a body ground. There should be a hole on the inner fender for it to be bolted to. The other eyelet goes to the fuse block. If you take the lid off, you will see a little bolt sticking up. Attach is there. The "odd" plugs at the battery terminal: One is for the alternator The picture below has something to do with the auto transmission.
The one below is your MAF.
Wish I could help more. Sorry, I'm not to familiar with S13s.
Modified by stlwaco at 3:26 AM 4/6/2008
Modified by stlwaco at 3:29 AM 4/6/2008
Modified by stlwaco at 3:34 AM 4/6/2008
Modified by stlwaco at 3:36 AM 4/6/2008
Modified by stlwaco at 3:47 AM 4/6/2008
