So im currently troubleshooting my headlight issues.. They will go up, but wont retract. Also, only one headlight works. The other is a brand new bulb.. All of the fuses checked out fine. I saw the thread about headlight issues, so I followed it and found this. I went ahead and got a brand new combination switch, but still have the same problems. Any ideas what could have caused this type of overcurrent in the combo switch? I imagine I'll find my problem when I find what caused this..
Ill continue searching.. I'll try replacing the retractor relays.. I dont have a multimeter at the moment to test for voltage at the headlight thats out yet. Assuming the relays are good and theres no voltage at the headlight connector, what suggestions do you guys have? Headlight timer?
