vg33t wrote:Ok, it looks like if I modify the trans mount bracket I can slide sthe trany back an inch. Has anyone had to do this? I thought you could use the stock transmission mount bracket without any problems.
Sounds like you bolted your trans mount up in order to make engine mounts correct? You'll find that you'll have to modify/remake your trans mount for sure... as it seems you have noticed. From what I can remember (it's been over 1.5 years ago) I made my mounts so that they bolt the motor up 1/4" or so back from the R32 member holes if you have a 32 member laying around and can compare your plates on the S13 member vs the r32 member side by side. My motor sits in perfectly with a fair gap between the radiator and the crank pulley. In the correct position you might have to "massage" the tunnel to keep the trans from rubbing, but I'm not sure how that will be with an auto since I've never seen or delt with one.
I would suggest using 5" wide 1/4" plate with 4" deep 1/4" channels (this is off the top of my head... but I'm pretty sure those are the right numbers)... I ran the numbers and they should hold up really well... mine have been great so far...
Hope this helps.
Modified by rbsileighty at 9:44 AM 10/16/2005
