need some help finding a leak
AP Autosport
Car: 89' Sil40 w/sr20det
I have a 89' 240sx with a sr20det in it, after buying this car I noticed a smell that didn't smell like the normal oil or coolent, but maybee a mix. Also, there is oil in the rad. overflow tank. The smell is not really there untill you are moving at a pretty good speed. I thought head gasket but I ran a comp. check and had even no. across the board and no spark plugs were fouled so I can rule out it leaking in to the combustion chamber. My next thought is the turbo, since its water cooled. My only problem is how can I tell, I don't want to replace it with another t-25 and I don't want to upgrade it untill I know there is not a problem somewhere else.
summary:1.sr20det motor2.oil in the coolent3.compression is fine and even, and no fouled plugs4.burning smell when in high gears at mid to high rpms5.I think it might be the turbo
NISTECH
loan a coolant pressure tester from autozone or some place like that. pressureize the system and see where it comes out
