Need some help CD Changer
MattPalmer
Car: 2006 Infinity M35
I have a 2006 M35 and I am having trouble with my CD player.
My CD changer has a disk in it and it is having a hard time ejecting. I should have pulled it out but wanted to listen to the balance of the media. Now the disk is stuck in there. Early on it was mechanically trying to eject the disk. I read on line that I should disconnect and then reconnect the battery. I tried this and now it won’t attempt to eject (no mechanical sounds). There is only 1 disk in there now and I can’t get it out. I have replaced the 15 amp fuse which blew in the side wall behind the emergency brake and it has not blown again. The disk player reads please eject disk. When I hold the eject disk (up to 1 minute) the screen shows it is trying to eject electronically but not mechanically.
As a side note now my sunroof no longer does the 1 touch slide operation. When I touch the button it moves an inch or two. I have to push the button many times in order to get the roof open or closed.
Thank you for any insight Matt in Oregon
