Need some guidance
NYCQ45
:help OK here we go again,other than this being a reliable car it still occasionally has some problems and I cannot find a service manual for it,so I'll ask here.
Car goes over bumps and I hear a creaking sound.I assumed Struts so I ordered them from a site here that was suggested by some other members.The Temp control is not displayed anymore unless I bang on it and now it doesnt turn on at all.
The odometer I see the light but it never displays anything..
Broke that little fragile thing to open the sunroof now its permanantly closed.Power mirrors do not work at all.Any help is greatly appreciated I would rather do it all myself because it NYC so it cost a lot more here than anywhere..
TIA..
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
Creaking sound is probably upper links or tie rods in front suspension. Struts don't make noise, car just gets bouncy over bumps. But good to replace everything at once anyways.
Temp control unit can be removed and fixed by: http://www.jerrytucker.net
Trip odometer (digital) or main odometer?? The bulbs can burn out behind the digital display. The main odometer can stop working (mine works sporadically).
That's a start....... how many miles on the car?
NYCQ45
Darn it I ordered the struts assuming that was the problem,the car has 114K miles on it and its the trip odometer that has never worked since I have gotten this car but it lights up though.Also I assumed struts because the car sways a little when I go over a bump..
NYC - Also check upper links and tension rods (freuently dead by now).
Fred probably has the sunroof switch assembly on his "parts Q", email him (PalmerWMD).
Power mirrors could just be a fuse, but I'd have to check the manual... I'll keep an eye out for a FSM for your car (I just sold my last one).
Hang in there, we'll get you back on the road like it oughta be!
My sunroof switch is broken too. What Im going to do, after I do chain guides, power steering, brakes, and other more important things, is replace the entire switch console. I'll be calling some junkyards around the country. You'll notice that its easy to remove and pops right off. Takes about 1 minute to replace.
OLU40
Car: Infiniti's Martial Arts, Science, Reading, Sports, Computers, Electronics WOMEN!
NYCQ45 wrote::help OK here we go again,other than this being a reliable car it still occasionally has some problems and I cannot find a service manual for it,so I'll ask here.
TIA..
Hey NYC I'm here in Queens if you need some guidance as well. Messing with these Q geniuses helps alot. NYC can be a bad place for any car. That noise is 90% leaning towards your u-joints (upper links). I had the same problem last year. This car is rock solid reliable although 91 had some issues. Hit me up. Peace.
