Need some good advice on rebuilding my SOHC KA
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Hey what's up guys, I need to rebuild my SOHC KA (loosing a lot of compression into the head/burning oul) I have a extra longblock so that's not to big of a problem.
My question is what rebuild kit do you recommend? it will be N/A for a few months after I rebuild the engine but my HP goals would not be more then 225-250rwhp Turbo.
I did not find that many kits, just the Ebay crap ($350), Topline ($500) and This one.. from IPP http://www.importperformancepa....html (see #2)
Complete Gasket Set Copper Head Gasket (to 30 psi) WISECO Pistons (89.5, 90, 90.5 & 9-1 comp) (89.5, 90, 90.5 & 10.5-1 comp) (89.5 & 8.5-1 comp)
ROSS/Wiseco Stock Bore 89mm ROSS Performance Rings Performance Wrist Pins TOGA HP Main Bearings TOGA HP Rod Bearings TOGA HV Oil Pump Thrust Washers Expansion Plugs
$979
I'm interested in the IPP kit because I want this to be semi reliable as a turbo daily driver 225-250rwhp on a tuned ecu. But is it a good deal? I have never used TOGA parts... are they any good?
Anyone here have experence with IPP?
I have about $1800 (less is better.. $1800 is my max) for this rebuild including machine work and having the bottom end put together, (anything specific I should have done?) and a rebuilt head. I would like to do the rods but it's not in my buget
I searched and these's not much info for rebuilding SOHCs every time I ask the question people point me to DOHC rebuild kits the nico sponcers don't have kits for SOHCs
Any pointers would be great.
Modified by Kenrik at 1:53 PM 6/22/2006
mikerbike
I recomend you not use the Topline set. Mine ran fine for almost a year N/A. I turbocharged my Single cam about three weeks ago and the head gasket broke between two of the cylinders about 1 week ago. Who sells that copper head gasket you were listing? I want one.
mikerbike
Oh, Importperformance parts. Nevermind. Thanks.
ridin4life
go to turbo240.com i know that all they have are dohc rebuild kits but call them and tell them you have a sohc and ud like a rebuild kit. they have sohc 8.8 to 1 pistons for the sohc. they should be able to supply u wit the sohc pistons instead of the dohc pistons.there forged and you'll be ready for anything u can throw at that motor
Import_Ant
I have heard of people using a Cometic DOHC head gasket and just trimming off the end-piece that covers the timing cover and replacing it with one from their stock head gasket or making one from silver McKanica. aside from the timing cover portion of the gasket, the DOHC and SOHC head gaskets are identicle, and all that piece is, is an oil seal.
I second the reccomendation to NOT use TopLine timing components. A good friend of mine did a rebuild of his DOHC Ka and the tensioner went out within a very short period of time (within break in period) as well as his topline oil pump. LOTS of people over on http://www.ka-t.org have had numerous issues with them as well. I would reccomend going to the Courtesy Nissan website as they are a sponsor and ordering the OEM Nissan timing parts.
You can also order an OEM oil pump for an 81-83 280z (L28ET engine) It runs a little higher volume and is a direct bolt on for the SOHC. I plan on running one because the oil feed line and oil cooler I'll be running will put more of a strain on the oiling system than I feel comfortable letting the OEM pump handle. I don't know if you plan on running an oil cooler but I would highly reccomend it as they are cheap insurance for an expensive engine build.
I should be doing a SOHC build up within the next year or so for turbo and plan on doing everything I just listed as well as some extra goodies. We'll see how finances pan out though.
I'm not sure how balls-out you're planning on going with the engine but you can ask how much they want to balance your rotating assembly. basically they'll take your flywheel and clutch and assemble your entire short block and balance it out. It isnt neccesary for normal street cars but if the price is cheap and it's in there already, it's an added bit of insurance as well. (I think my friend paid 80$ or so to have his rotating assembly balanced while his engine was in the shop)
If you're not having the shop assemble your head as well, you might ask them how much they want to inspect your head to make sure it's not warped and mill the surface so you get a good seal w/ the head gasket. Most likely they won't charge much to check your deck tolerances, it's especially helpful if you know what the need to be. go to http://carfiche.com/ and pick up a FSM if you don't already have one. If they need specs on what the tolerances should be in the bottom end or head you will already have them at your disposal.
I have to get going to work but that's all I can think of for now. I'll come add more if I remember anything later.
mikerbike
Dang. That sucks. I only got a gasket set from Topline, not a whole rebuild kit.
I think I will try using the DOHC head gasket. I mean, I already have the part that covers the timing cover.
S13FX
Car: '69 l20b Dimeski :)
Hey AMS Does offer a full SOHC rebuild kit for lik 1700 It's a great deal.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Don't kill me but...
I bought a SR20DET... ** ducks and runs for the hills
Import_Ant
Kenrik wrote:Don't kill me but...
It's your car why do you need acceptance from anyone else for what you want to do with it?
