Need some F.A.S.T. help
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
I've tried searching and it looks as though the question has been asked multiple times in the past but no one has offered an answer.
Does anyone know the part numbers for the following items for a very late S2 RB25 with the R34 CAS (black plastic)?--TPS--ECU coolant temp sensor--PCV valve
Anyone know of any compatible USDM parts? I have a friend of a friend in Japan who works for Nissan (corporate) and can get a little bit of a discount on some OEM parts. I've been having some issues with my motor since I wired in my DIF fan controller and I think I need a new ECU coolant temp sensor so I figured I'd ask him to mail one to me and perhaps the other items if it's not too expensive.
Thanks!
jonh317
Car: 240sx s13 sold
05 Mit Evo
22620-AA509 TPS11812-41B00 PCV22630-44B20- engine coolant sensor25080-89907- senor temperaturePCV and both temp sensors have usdm conversions. i used nissanparts.org, and search the part numbers and those 3 came up the tps did not. i do not know which temperature sensor is which, dealer might be able tell. parts numbers obtained from nissan parts catalog
kouki-gymkhana
Thanks so much for the info!
