Lsnaple »
https://forums.nicoclub.com/lsnaple-u923.html
Wed Sep 14, 2005 9:42 pm
i have a 95 240sx base model with power windows, power locks, power sunroof, poewr mirrors........with this same problem. the car runs and drives fine but only the headlights, the blue light for high beams,the horn, and the clock in the cluster works.
first happened because i changed my cd player in the car. i bought a harness and attached the wires correctly (did not cut factory cd player harness) except for the dimmer to illumination. noticed i blew the tail lamp fuse and noticed that another fuse was like a 30 when the panel said like 7.5 i think, so i replaced it with the correct one.the parking and interior lights would not work, but the cd player would be lit up and work along with the clock light and the headlights....but the parking lights all worked when i would use the turn signal or brake. replaced the tail lamp fuse and disconnected the dimmer and taped it off and now it all works. im so happy.
go for a ride later and the cd player shuts off a few times...hmm somethings up. but everything still works good. park the car at a friends house to go get him to come for a ride, shut the car off and now the power locks dowt work. anyway i go get my friend hop in the car and now none of the power options work. the wipers dont work, none of the other interior lights work, side-markers dont work, turn signals dont work, brake lights dont work, none of the electrical (except for the engine/drivetrain) works. only headlights, the blue light for high beams, and the light for the clock in the cluster works.
i checked all fuses ( except the box ones, dunno bout those ) put oem cd player in, and even disconnect the battery for a few minutes, and the problem remains.
theres only 2 causes that i can think of, one being those box fuses. the other is that i didnt attach the antenna to the new head unit because i dont have an adapter yet and i forgot to tape it up for the time being so maybe that hit something and shorted it out....i dont know.
THANKS FOR ANY HELP I NEED THIS FIXED ASAP!!!
